Discuss 240v LED Strip Light on Mains switch in the Lighting Forum area at ElectriciansForums.net
Hi all,
Hoping for some guidance, which would be much appreciated.
I currently have some Florescent Lights under my kitchen cabinets operated by a light switch and would like to replace with LED strip lighting.
I have purchased some 1 Metre 240V LED strip which is fitted with a 3A UK plug.
50645
Is it a simple as removing the plug from the LED strip and wiring the Live and Neutral into the Junction box of the existing lights?
Thank you in advance, much appreciated!
Aidan:)
What the old guys said above.
Obviously ensure the circuit is dead.
Make sure the cable from the junction box is secured also, either by cord grip or p clip etc.
It would also be advisable to ensure the protective device is the same rating as supplied by the manufacturer.
I was thinking about this as well.
I presume that the fuse in the plug will be 5A and the existing florescent lights would be connected to a 6A breaker. The cable and switch on the LED should be capable of taking 6A instead of 5A.
Yes, lots of presumptions there...
Hi all, thank you all so much for your responses.:praying:
The Junction box for the existing florescent lights are not attached to an FCU, only a 6A breaker at the consumer unit.
As the LED lights are factory fitted with a 3A fused plug, would this cause a problem if the plug was removed and connected directly to junction box?
Many thanks once again, i can only apologise for the ageism comments! :p
kindest regards gentlemen!
Aidan
Out of interest what do the manufacturer's instructions say?
Note to George - I know they don't have to be rigidly adhered to.
TBH a 6 amp MCB would operate much quicker than a 3 amp fuse so I wouldn't loose any sleep if it wasn't fused down.
Reply to 240v LED Strip Light on Mains switch in the Lighting Forum area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
First time poster here seeking a little advice/confirmation I have spurred off to a fused switch and from there running two 2.5mm cables to the...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
