Discuss 25a mcb in the Electrical Tools and Products area at ElectriciansForums.net
Also remember manufacturers guidelines will state that only their mcb's should be fitted to their dist-boards so unless you can justify ignoring this regulation i wouldn't go down that road, you can justify it on occasion when a manufacturer makes a few different brands using same template thus identical mcb's dimentionally, Sneider owner of Merlin, Sq-d, telemecanique and Modicon do sometimes copy the mcb template across their different brands.
Yes i know other mcb's may fit but since the regulation stating 'manufacturers guidelines should be complied to' then this means the goal posts have shifted so doing so could contravene reg's
Reply to 25a mcb in the Electrical Tools and Products area at ElectriciansForums.net
As a retired electrician, I need to specify a new type B board for a village church. Principal load is heating. Ipfc phase to phase is 1.1kA...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
The hottub is 8.1kw so will be 35A max output , I’m going to put it on 6mm 3core swa to an isolator then to the hottub. Would a 40a b type be...
