Discuss 29 Amp double oven fitting in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I am installing a new double oven and ceramic hob where a stand alone oven used to be, the oven is rated at 29amp but not sure what the ceramic hob is, current wiring is 10mm from a b40 fuse in the consumer unit to a 45amp cooker switch and plate, I know that I need to change the plate for a dual one but do you think the b40 fuse will be man enough and is 29amp high for a double oven.
I would think you should be OK with what you have already judging from afar, don't forget Diversity is applied to cookers where by not all of the cooker will be used at any one time, it's difficult to explain on an internet Forum, but if you are still worried, contact an electrician to get the wiring, MCB checked out, if you post your location there maybe a Forum Member near your location who would be willing to take a look and reassure you, good luck.
Reply to 29 Amp double oven fitting in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
I have a double oven connection unit. Fed with 4mm cable,40 amp MCB. Hob connected to it with 4mm cable. Bought new oven,stated 16 amp but with...
Hi, My current oven is hardwired to a fused connection plate with a 13Amp fuse inside and power switch. That is then connected to the MCB labelled...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
