- Reaction score
- 904
On the few I have fitted previously, there is usually a ballast on the back of the tray which hold all connection etc, and when fitted all connections etc are hidden away.
Looked at one today, which had stopped working, but no ballast. You have you classic connecter block to wire in the LNE.
IThere is 230v at the connecter block, but at the pins that the bulb plugs into there is something like 18-23 volts. Is this correct? The chap said its his 3rd one in as many weeks so thinking is the fitting a duff?
