Discuss 2nd fixing should but oh no..... in the Electrical Forum area at ElectriciansForums.net
depends on how good the muck spreader is.Shouldn't the wall be flat?
usually you need a 35mm back box and a perfectly flat wall surface.Anyone had problems with these slimline fittings,they are so slim,I just can’t get my head round it.
They are not fitting correctly to the wall,looks like these walls need to be flat,not happy with them at all .
Not always these days,dot & dab.Shouldn't the wall be flat?
"make" you mean they bend the flanges off fast fixes and then repackage them as their own?Don't they make a trimless box to go with them?
If you sign up to the schneider trade page, they send you a drinks bottle, t shirt and you can get a 1 gang switch from the same range as a free sample. It is worth several quid so you may one day find a use for it! have to say i was not impressed, you have to push little plastic bits in to take the front face off to then install the 2 screws, the faceplate then clicks back on. but try removing it if its already installed! I wouldnt recommend them to customers... avoid them where possible.
Reply to 2nd fixing should but oh no..... in the Electrical Forum area at ElectriciansForums.net
