DIYBlues
Hi Guys
I wonder if you can advise on a fan isolator I am installing....
On the reverse of the fan isolator I have the following markings:
Top L1 (common) L2 N (common)
Bottom L1 L2 (common) N
Originallly I was going to wire it up supply to the top terminals and fan to the bottom terminals
as seen in many other wire diragrms. However the fan Isolator I purchased as the terminals
marked as above.
Now I'm thinking I should connect the supply in all the common terminals regardless if they are at the top and bottom
and fan to the or L1, L2 and N terminals.
For clarity I have not included the blanked off L1 and L2 terminals on the rear
Any advice would be greatly appreciated.
Regards
DIYBlues
marked as above.
Regards
DIYBlues
