Discuss 3 Gang and 2 Gang -2 way wall switches in the UK Electrical Forum area at ElectriciansForums.net
Hello Every one ,
I just joined. I am looking for help in wiring a 3 and 2 Gang- 2 way switch.
I will be using the 3 gangs as 1 way switches, and a couple of the 2 Gangs a 2 way switches. Switches were imported from china, and came without any diagrams. I checked on the internet and found many diagrams, but they all show 2 and 3 COM pole terminals. My switches have only L1, L1.1 and L1.2 and L2, L2.1, and L2.2 etc marked at the terminals. see pic of the 3 gang 2 way below. Could someone please tell me how to wire this switch , for both 1 way, and two way lighting.
Thank you
Conrad
Without testing it is difficult to be certain.
L1, L2 and L3 are probably the three Commons.
L11, L21 and L31 are probably the three L1s.
L12, L22 and L32 are probably the L2s.
So the switch terminals are:
L1, L11 and L13, L1 being common and L11 and L13 being the other terminals to the switch.
That is speculative as it should be tested to confirm.
Do you have something that beeps or lights up if you touch 2 ends together?
Continuity tester?
I recommend; put that switch in the bin.
But the switches you need from a reputable outlet
Continuity tester?
OP is in Thailand, so even though imported from China, that may be all that's available.
that is a three gang switch, each gang is a two way. L1 is the common for that gang (live in from the circuit), L1.1 is switch live 1 (to go to the light fixture) and L1.2 is switch live 2 ( used for two way control). on order to have two way switching you will need another switch like that
a photo of your switch backbox would help to identify what sort of wiring method you are using... if any!
Thanks everyone, I wired all the L1/L2/L3 together and powered L1, and a test lamp, and used the other leg of the test lamp on the L1.1/L2.1/L3.1, and the lamp lights when switches in closed position. when the switches are in open or OFF position the L1.3/L2.3/L3.3 are alive and light up the lamp.
Its just a NC , NO setup . I will be using all the 3 Gang 2 way as one way switches, and need only two areas where I need two way, and that is in the Garage, and one in the Garden.
Thanks a lot for the enlightenment.
Reply to 3 Gang and 2 Gang -2 way wall switches in the UK Electrical Forum area at ElectriciansForums.net
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi, Need some help with an odd setup. I have a large room with many lights that i separated into 2 sets. In Box 1 there is the 14/2 power in, 2...
