Discuss 3 gang switch options in the UK Electrical Forum area at ElectriciansForums.net
J
J_T
Hi, I'm wiring a 3 way lighting circuit along side 2 x 2 ways. I need a 3 gang switch that contains 2 x 2 way switches and 1 intermediate to suit all circuits and look like all my other light switches.
Does anyone have any experience if switches of this type are freely available? Can I pick and choose what each switch contains or am I fairly tied down to a number of options?
JT
Standard grid switches where you can have whatever switch modules you like ie. intermediate and two ways on same plate, just click them in and screw front plate on :)
Using click you can get all switches onto a single gang plate, MK and GET ultimate for example will require a 2 gang
Mk and get will be easier to get hold off and you can swap in dimmers should you need to
Click will be cheaper (assuming you don't get it from Cef)
MEM Domestic plate switches can be removed via a small brass screw at the rear and other switches installed in place, I have done this countless times myself, and they are cheap compaired to grid switches and 10 amp rated.
Reply to 3 gang switch options in the UK Electrical Forum area at ElectriciansForums.net
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Hi all, looking for a little advise on how to wire in a 2 gang intermediate switch. I'm doing a first fix on a house extension and it's 3 storey...
