Discuss 3 of 6 GX24Q-4-pin type pots lights went out together any ideas? in the DIY Electrical Advice area at ElectriciansForums.net
70Tbolt
3 of the 6 lights run by the same switch went out at the same time. Tried new bulbs, switching bulbs that worked no go. When the switch is off and I go to insert a new bulb it will flash on momentarily. Are these controlled by some type of ballast? Thanks
Yes, if more than 4 years old, those are compact fluorescent lamps with an external ballast.
There are replacement lamps with the same base that are LED and require that you bypass the ballast (rewire the lamp). If I had a bad lamp or a bad ballast, I would replace it with an LED. You can find them on ebay and amazon, as well as other dealers. But be extremely careful to make sure you are getting a bulb that will fit and meets your needs. Also, you need to know how to wire it. It isn't a simple plug-in replacement.
If they all stopped at the same time that possibly indicates a poor connection.
House is 6 years old, so would the ballast be by one of the three that went out I hope?
You'll have to look inside to know. Make sure to turn off the circuit breaker before opening. :)
Reply to 3 of 6 GX24Q-4-pin type pots lights went out together any ideas? in the DIY Electrical Advice area at ElectriciansForums.net
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
Hi guys, first time posting, please bare with me! I have an old test chart as shown in the pics that i would like to get running. Everything...
