Discuss 3 phase 10kwp system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
B
bigsparks
Hi All
We are designing a G83 10kwp pv system to go on a 3 phase supply, using an SMA Tripower 10000TL. When calculating max AC amps will it be calculated at 10000 / 415v = 24/25 amps? We are looking to install one 4 pole AC isolator.
Also what size tp mcb is is best to install.
Hi All
Thats not the way to calculate 3 phase currents. Assuming balanced
Current = Power/3/voltage
So in you case
10000/3/230 = 14.5A
Sanity check 3.68kW on 1 ph = 16A
3 x 3.68kW = 11.04kw @ 16A /phase
Cheers for the reply
So a 16a tp mcb will be suitable on this install then?
UK Power Networks are the DNO here and up until recently they had been advising 3.84kw @ 240v =16amp was ok, which after speaking to them a week ago appear to have moved in line with other DNO's and dropped to 3.68kw per phase.
Reply to 3 phase 10kwp system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I know the effect of a lost neutral (floating neutral) on a 3 phase system, and the theory of why the line voltages can vary. However, I have...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
For power outages, my solar inverter (+battery) is able to take on the entire house load - as long as I unplug my collection of vintage kettles...
I am trying to understand 3 phase volt drop. I understand single phase VD. Lets say we have a 70 meter run of 35mm, 5 core cable from the supply...
