Discuss 3 phase db converted to single phase with 10mm earth in the UK Electrical Forum area at ElectriciansForums.net
daveelectrician
Hi.Today during my job at a police station, took cover off brand new KQ 3 phase SquareD db (recent db change by different firm) to connect my new ring to one of the ways and found that the 3 phase db had been converted to single phase. 25mm double insulated tails live and neutral, L1, L2 and L3 linked out using some 10mm earth cable. To me i would say that is a c1 fault, so refused to make my circuit live until c1 was rectified. What is everyones opinion on this and does anyone know if there is a linking kit available from schneider.
If all 3 phases are connected together and to the line side of the incommer, surely that means 415v for the whole system?!
I'm not an expert in 3 phase, but that just sounds plain wrong (and that's before we get to using 10mm earth as a line conductor!)
Have you been in touch with Schneider?
It's not unusual to convert a board like this. One danger is the neutral rail being overloaded.
How do you work that out?
Single phase conversion kits are available when using a 3p DB with a 1p supply.
Linking out using 10mm is dog rough but not a C1 imo.
Sent from my HTC Desire C using Tapatalk 2
No I think the Op means that it's a three dis board fed by a single phase and neutral...no?
Oh, ok, that makes more sense... It sounded like he was talking about a single phase board being fed by all 3 phases!
My bad!
:blush5:
I really shouldn't use this forum after beer...
Deleted (cos I was being stupid!)
This is true, but it sounds like a 3ph dis board which has been converted to single phase.
The supply to it will be single phase line, neutral all that's been changed in the board is the 3 bus bars internal to the db have been linked together, albeit roughly.
100amp BS88 2X 25mm (live/neutral) tails into 4 pole tpn 60947-3. 25mm live in L1 terminal, linked to L2+ L3 with 10mm earth cable. 8 way tp board 1 tp way spare.
When fitting, make sure to fit as per picture on link. They come with no instructions.
I fitted one last weekend, as I had a similar issue that was a defect on EICR. Mine was slightly worse, as they were linked with 6mm2 singles.
I have seen these linking kits installed under the main switch, which is not a good idea as you have a nice shiny piece of live metal when cover is removed.
The linking kit sits nicely on existing bus bars, and the main switch then holds it in place.
Reply to 3 phase db converted to single phase with 10mm earth in the UK Electrical Forum area at ElectriciansForums.net
Recently started a retrofit where the 3 phase dB has been fitted with bushes through the galv trunking. The single phase supplies outgoing have...
Hi, searched the forum but cant locate anything similar so apologies if ive missed something. Ive got a new hob to install in the kitchen...
Been called to help a friend who can't get anyone to look at his car lift until next week and it's stopping him from working. I said I'd have a...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
