Discuss 3 Phase meter on solar PV installation not working in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
T
Tilegem
HI
Just installed 14kWp Solar PV system into three phase supply. Everything seems to be working correctly except the 3 phase electricty meter. Inverter says its genererating volts and and amps all OK but the meter (Elster TPN100) is not indicating any accumulation of watts and the red LED is not flashing although the inverter says it's generating power (several kw).
Any one come across this problem? I suspect it's a faulty meter?
Regards
Tilegem
Have you tried a clamp meter on the output of the inverter? Just to make sure it is producing power.
There are two versions of this meter. Import only and import / export.
Reply to 3 Phase meter on solar PV installation not working in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Help please, this is my first post on this subject regarding solar panel / battery installation into house with 3 phase supply. I am a DIY level...
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
