dldavies
I am wiring 3 3 phase motors, 1.1 KW each via 3 STOP/START manual starters. If one starter locks out for any reason, the others also need to close down simultaneously.
I initially thought that I would have to have a relay in each starter connected in series but I've realised that won't achieve what I want.
The other alternative is to bring the supply into a contactor, then to the TP/N distribution board out to the starters but this would mean I believe that each starter from the auxiliary contact would have to be connected back to the contactor coil so that whichever motor locked out would open the contactor.
Is this correct?
Thanks in advance
Is this correct?
Thanks in advance
