Discuss 3 Phase Motors in the Canada area at ElectriciansForums.net
switched on
hi i have to wire up a few 3hp 5A 3 phase motors and usually use a 3 core swa but is there an alternative cable to use apart from singles?? Thanks for your help in advance
many industry driven motors have interlocked isolators, where a pair is also used, so when the isolater is in the off posistion the feed is also cut via a contactor
why do you want to use another cable???
SY cable seems more expensive and perhaps as difficult to terminate.
In an industrial setting mechanical protection is needed.:confused:
Depending on the situation of coarse ! But I always prefer to see plastic shrouded armoured copex with swivel , top hat glands for motor connections as it gives good mechanical protection whilst still allowing good flexibility for maintenance and such like . It also means you can easily pull in new singles if ever needed which in turn I also find it a lot easer to connect singles into smaller motors and isolators as opposed to a multi core cable .
Reply to 3 Phase Motors in the Canada area at ElectriciansForums.net
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Hi All, I have recently purchased a motor soft starter from aliexpress for a 3 phase motor Before connecting load I measured the input and...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
