- Reaction score
- 0
ive a 3 phase static inverter with a 4 pin no Neutral power output 420 v. Is it possible to use the 240v power source Neutral on the inverter, change the socket output to 5 pin and use the input power source Neutral as in effect a slave Neutral. The Neutral will not be connected to any wiring in the static inverter only the new socket ?
