Discuss 3 phase supply in the UK Electrical Forum area at ElectriciansForums.net
I
Hi
Wondering if someone out there has any idea how much a new 3 phase 100amp supply is compared to the cost of a single phased supply on a new domestic property.
Cheers
worked on a job in Leicester where the 3 phase supply was split into 2 separate supplies and the property owner says e-on charged him 8 grand to split the supply and install 2 intakes 6 feet away. Not sure if this will assist you in anyway
OP....contact your DNO supplier. Cost will vary re 3 Phase available, nearest point to get 3 Phase, any 3rd party land involved and or the highway. Can the Transformer take your additional load,
Reply to 3 phase supply in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
I have been asked if I can wire a motor for a car lifter in a domestic garage, however the motor is 3 phase and only single phase is available in...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
