I apologize if this has been covered before, but this 3 way switch has me chasing my tail.
I have recessed lights in the hallway with two 3 way switches, one being recently replaced with a Lutron dimmer switch. The lights only work when the switch closest to the line (“switch 1”) is in the up position and the dimmer (“switch 2) can be toggled to turn the lights on or off. When switch 1 is in the down position, switch 2 has no function. Note: the switches are between the panel and load.
Switch one has the hot from the line coming into common. 14/3 runs from switch 1 to switch 2 with the red and white on the traveler posts. The black from the 14/3 runs from switch 2 common to the load.
Is it possible my new dimmer switch has a broken leg? I’m fairly sure the wiring is correct, but at this point I’m stuck.
Thanks,
AG
Thanks,
AG
