Discuss 300Mamp in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
brian fox
could some one HELP
in a commerial property with computers
there is a split load board the rcd is 300m amp with hot water immertion,
Radiels,2 socket circuit and ring circuit 6 amp on the rcd should the 300 be changed to a 30m amp rcd
RCDs with a sensitivity of 100mA to 300mA are typically used for commercial property and equipment protection (particarly where numerous items of equipment are supplied through the protected circuits).
Reply to 300Mamp in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
Good Evening. I’m currently carrying out an EICR. I have a cooker circuit radial with a 32amp mcb fed from and RCD split board. There is a 45amp...
Good morning, Ive a dry covered area by the side of the house where I’m wanting to some welding art, I bought a 200 amp tig welder , that says it...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
