Discuss 302 written exam on the city and guilds 2365 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
You will be asked to draw out the fault path on various earthing systems.
They may ask random stuff like what fixings you would use on brick,plasterboard etc to fit all types of containment and fittings.
Definately be some formulas in there.
I was asked to explain then draw how an rcd operates and its purpose within an electrical system.
Purpose of earthing.
I cant remember all the questions bit they were just a few that i had!!!
give me a pm ill guide u threw it m8 i had it the other week version a
Ive just passed it with 62.5%, the passmark is around the 50% mark.
Questions were on.....
Inductance (formula questions)
Capacitance (formula questions)
Impedance (triangle)
Power factor (triangle)
Power factor correction (knowlege)
Illuminance (formula and knowledge)
DC Motors (knowledge)
Star Delta (formula questions)
Motor Starting (knowlege)
Relays Solenoids (knowlege)
Space Heating (knowlege)
So practically something from every part of the unit. Revise this stuff, make sure you can explain how things work and you will do fine.
Craig
I found Swindon Massive very helpful and their free sample questions were perhaps more of a challenge than the 302 questions. Obviously you'll need to revise your course work too. Good luck.
Reply to 302 written exam on the city and guilds 2365 in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
