Discuss 3A Fuse for fan in the UK Electrical Forum area at ElectriciansForums.net
LewisM
Hello, I have to replace a fan with a timer for a client who has already purchased a fan, the new fan requires a 3A fuse as per manufactures instructions, currently only an isolator is in place, am I right in thinking that the switch live on a timed fan only acts a trigger so if I swap the 3 pole isolator for a click one wich is a 3pole isolator with fuse carrier in it and place a 3A fuse on the load side of the permanent live that this would be sufficient?
That's exactly what I do. The fan runs on the permanent live so as long as that is fused I feel it's covered the manufacturers requirement. If I'm installing from scratch though I'll run the supply to the room through a 3a FCU
Never saw the need for the 3A fuse requirement.
Most fans run from a 6A MCB protected lighting circuit.
A 6A MCB will always trip before a 3A fuse can blow.
So a 3A fuse is a pointless requirement.
A 3A fuse is for fire protection, the assumption being a locked fan motor will rupture a 3A fuse quicker than the protective device at the consumer unit. A university study came to the conclusion this was inconclusive based on manufacturer variation.
I used the Scholmore SFCU grid switch, to take into account manufacturers instructions for insurance purposes.
However, to put it into prospective, I replaced a fan once that birds had nested it. The fan was jammed, and burnt out and the local 3A hadn’t gone, and the owner was unaware if the 6A mcb had tripped. Greenwood Airvac installation instructions say ‘Fuse: 3 amp normally required (when fan is supplied from a 6A lighting circuit no local fuse is required)’.
Presumably using the FCU and the 3-pole switch?
Obvious question on the "must be 3A fused" guidance is whether that implies both permanent live and switch live have to be from a 3A fused supply as then you would need 2 FCUs.
I would imagine that the motors have (or should have) a thermal fuse to prevent overheating anyway as a motor rated as taking 0.1A or so is going to burn out long before a 3A fuse goes. More so if the bearings get tired and high friction so it is on permanent overload (but not locked).
I just used the one fcu, for the permanent live which runs the fan, not the trigger.
Reply to 3A Fuse for fan in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
i am wiring up a new en-suite: it is about 1.7m square, shower cubicle in one corner, toilet in other, door between, basin next to shower. I will...
Hi, The house I've moved in to doesn't have an extractor in the main bathroom so I'm looking at placing an inline extractor in the attic directly...
