L
Lukethoma1985
Hi guys, hope your all well and enjoying the weekend. Just wondered if you give give me abit of your expertise.
Been asked to sort a few bodges out at this car recovery place. When i say bodge jobs, it mist have been hell of alot of DIY for the last 30 years. New owners have took it over.
What do you reckon would be the best wiring system to run to a vehicle ramp thats 2 metres from the wall. Currently the isolator is cable tied to a girder and then sy cable hooked on a shelf 2 metres away and then dangling to the ramp. He want the isolator moving to the back wall then cable clipped direct around the workshop corner to the ramp. The cable run will then need to go across and down to the ramp. The last electrician was going to use steel trunking but he kept messing the workshop ablout. I was think cable tray fixed from the wall so its in the verticle position goin horizontal to the ramp and the 90 degree bend down to the ramp fixing flush down the arm of the ramp. Using SWA. Would the cable tray be strong or would it flap about? Ive never used it before. What do you reckon?
Many thanks guys
Many thanks guys
