Discuss 4 Core SWA - 2 Cores RCD protected, the other 2 not ... in the Australia area at ElectriciansForums.net
U
Unswitched
Hi guys
SWA feeding outside lighting and socket outlets etc.
Set up like this:
Single phase.
L & N T&E out of MCB in main board to feed sperate enclosure with only an RCD module in. So L&N feeding an RCD.
Then, 4 core SWA is glanded to this board.
2 of the cores (L/N) connect to the Mains in side of the RCD (with the t&e)
The other 2 cores are on the load side of the RCD.
So, effectively 2 sets of L/N are taken to a junction box outside somewhere, where I assume one set that is unprotected go to outside lights and the RCD protected L/N pair are taken to socket outlets?
All of this controlled by 1 MCB
Is this correct, I can't really see why not?
What are the cable sizes of the T&E and SWA?
I thought fixed lighting outside and out of reach did not have to be rcd protected (stand to be corrected on this mind :eek:)
Reply to 4 Core SWA - 2 Cores RCD protected, the other 2 not ... in the Australia area at ElectriciansForums.net
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
For context i am in my 2nd year in college and my head is going round in circles a question in my project for which i need to select the right...
4K
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
Hi guys, long time lurker first time poster. I have an SWA 3 core armoured cable buried that runs to my back garden. This originally serviced an...
