Discuss 4 MM SWA Used as D.C cable in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
N
Nickyrox
I would like to know if a 4mm SWA cable can be used for the d.c side or the installation. It is a bout 7 meters and one string is required.
dual core, yes.
Opinions differ as to the wisdom of bonding the sheath - I work on not if it's an isolating transformer inverter, maybe if it's a TL inverter.
Yes, I noticed some old posts about the sheath. It said it was only for mechanical protection and not electrical protection so it is not an issue with d.c cables.
Reply to 4 MM SWA Used as D.C cable in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
I know PV installers sometimes use SWA to carry DC into the house especially when the PV is ground mounted. Can anyone help me understand the...
