Advertisement - Content continues below
Discuss 4mm t&e radial circuit in the Electrical Forum area at ElectriciansForums.net
Hi Lads
Do any of you guys run radial socket circuits ( with multiple points ) in 4mm ? Do you find 2 x 4mm in the back of a socket a squeeze?
Only asking as I've just been passed 2 x 100m drums of 4mm off the lad doing the solar on a job I'm on for doing him a favour.... so 4mm radial... pain in the ass or not so bad ?
Cheers
Wetroom Store - Network Wetroom Suppliers
T
The Ghost
I do these a lot commercially in white pvc singles. Bit tight in the terminals but doable if cables are dressed/prepped ok. Radials seem to be coming into their own a little bit more now.
dinger809
I do these a lot, as I mainly do commercial. Some cheaper brands are a squeeze. MK, Schneider etc are absolute fine. Can even get two 6mm into an MK if prepped right
happyhippydad
Would be interesting to know if you can get 2 x 4mm AND 1 x 2.5mm? You just know you're going to need to spur at some point!
Pete999
Hi Lads
Cheers
I would install Radials with 4mm2 or 2.5mm2 with 32A or 20A Depending on the situation, or what Appendix 15 BS7671 stated, nothing new with 4mm2 32 A radials, it's all within the Regulations.
  • #9
Thanks.... it wasn't really a question of can it be done and how... as it's rather basic even for me, it was more of - is it a pain due to size of cable's.
Pete999
Not really use a deeper back box.
  • #12
More concerned with 2 x 4mm in a socket.
But as I've had a few good answers, I think there isn't more too add.
Starjack
Would it really be a spur though if it was a radial or would it just be another socket
T
Toneyz
Hi Lads
Cheers
No, we use 35mm boxes as standard on all jobs and MK sockets and have no problem. All sockets should take 2 x 4mm cables no problem by design.
Aico 3000 Range
Reply to 4mm t&e radial circuit in the Electrical Forum area at ElectriciansForums.net
Aico Carbon Monoxide Detectors
Top Bottom
