Hi all,
Quick question hope someone can shed some light on.
I have a single coil burner with the following labelled specifications;
1000 Watt
220/230v
50/60hz
It comes fitted with a 13 amp fuse, but after reading a short bit about fuses I got the impression it might be too high.
The calculations I came across was 1000w/230v=4.34 and another 1000w/230v=4.34*1.25=5.43
Would a 5 or 10 amp be better suited?
Thank you
Yaqub
1000 Watt
220/230v
50/60hz
Thank you
Yaqub
