Discuss 600M Electrical feed to farm house underground. in the UK Electrical Forum area at ElectriciansForums.net
Good evening.
I have been asked by a client to size and install an electrical supply from a meter position located 600M from the property and consumer unit. The client wants the supply run underground.
Supply is 240v single phase 100A TNCS.
Could anyone assist with size and cable type recommendations?
Any one else run such distances at 240v on private land?
Thanks in advance.
Steve.
Greetings.
I don’t want to be harsh, but My first thought is that if you need to ask this question on an Internet forum, then you should not be doing this sort of work.
Surely you know how to carry out basic cable calculations?
What is the estimated Ib for the proposed installation?
Welcome to the forum mate.
We are happy to help you out but we don't just give out info. How will you learn if we do that.
Give us your calcs and what you think and we will correct anything.
Everyday is a learning day.
600 meters is a long distance....
Hi,these decisions are important,as the supplier,in my experience,will not care if you make a bad choice...they will just let the owner live with it,and keep on billing...
I have had recent experience with a 460M supply,which really is a casserole of nonsense. :(
For a 50 amp SP supply over 600m you are looking roughly at a 120mm cable that’s about 15k worth of cable. If its for a bore hole pump or something obviously it’ll be a smaller load.
You say big cable, then say 35mm, make your mind up.
At 600m, I'd say the cable needed is likely to be a lot bigger than 35mm.
probably
[ˈprɒbəbli]
in all likelihood · in all probability · as likely as not · very likely · most likely · likely · as like as not · ten to one · the chances are · doubtless · no doubt · all things considered ·
[More]
at a guess. with out the loading who nose .
You got a head cold as well then Buzz (nose):tongue:
I don't think the OP will be coming back to this thread...
Reply to 600M Electrical feed to farm house underground. in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Looking to buy a house where the rear of the house is the rear boundary, onto council owned land (a footpath). I want to build a new...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Just thoughts Id share my recent fun and games on my parents farm.. The electrics are old. Its a 400yr old house with outbuildings just as old...
I'm converting my old garage into a two bedroom annex. At its nearest point it is approx 10m from main house. I plan it to be all electric, UFH...
