Discuss 80% rule in the Australia area at ElectriciansForums.net
F
Frosty69
Hi people,
I was talking to my niceic assessor the other day and he mentioned in passing the 80% rule. Ive not heard of this directly before but I assumed he means the max zs not exceeding 0.8 of bs7671 value? So am I right in saying that for example on a B32 the max in regs is 1.16 but I should be hoping for less than 0.9?
Thankyou
not quite. the max. for a 32A type B is 1.44. the 80% of that is 1.15. this is because you are measuring Zsat ambient temp. ( say 20deg.) whereas the operating temp of the cable is up to 70deg. the 80% rule is to allow for the higher rfesistance at the higher temp.
Indeed, also some of my clients insist on me putting the 80% values in the max Zs box on the test sheets, and others 100%
In practice any circuit that reaches the 80% value, should be investigated further, and ascertain how to make it lower
The max in the regs for a B32 is 1.44 of the top of my head. The 1.16 figure looks like the corrected value.
that's like saying you should drive at 25mph in a 30mph limit.
Indeed, also some clients of my clients insist on me putting the 80% values in the max Zs box on the test sheets, and others 100%
they are wrong, that is not the max Zs,
the figures on the chart on the back of the niceic pad also have taken into consideration the 80% but you should not enter that on the forms
on site guide figure, page 103 2D
to calc the correct ZS
230/(32*5)=1.44 B type breaker, this then gives BS7671 values.
Thanks for the fast replies and it was the osg I was reading from so they are the results taking into account the 80% rule. Thanks alot people
Reply to 80% rule in the Australia area at ElectriciansForums.net
Got my am2 coming up on Tuesday and I know I have to calculate my Zs readings Maybe I’m overthinking this but am not sure if I need to use the Ze...
I have a new Metrel tester and it has a .8 factor to apply to ZS. for the temperature adjustment for the cable heating up from ambient as a result...
Morning all So the site I'm based at recently had some work done (think partitioners). This package of work included electrical. This was...
8K
I have had a good search for this information but can't find it anywhere not even in my on site guide 17th edition. So imagine you have a CU with...
16K
The never ending debate about supplies for cooking appliances. ??? I've just received an email from a customer that I'm in the process of quoting...
