R
rmbb
I recentlybought a 1992 Cadillac Sedan de Ville. I’ve had electrical issues with it aswell as running issues.
Four fuseskept blowing. When I pulled out the aftermarket radio harness out of the radioand took the aftermarket harness out of the original radio harness, three ofthe four blowing fuses stopped blowing. The one that kept blowing was the onefor the ABS.
And the enginehas had poor idle and has been driving ok on some days and really bad on otherdays. It’s been as if it has been prevented from getting power. One has to be reallygentle on the gas pedal, especially on the highway where it can barely get upto 75 mph.
So thedigital gauge cluster has been dead. I took it out and a resistor had burntinside it. Today I also took out the Airbag module and a resistor has alsoburned in that one. Then I took out the Body Control Module and a resistor hasalso burnt in that one. I suspect the Power Control Module has also burnt.
Also thebattery has recently been replaced; they’ve done some rewiring I gather sincethe poles on the Euro batteries look different than the old US ones do. Also I get a little jolt from staticelectricity every time I exit the car and touch on of the doors. This has neverhappened to me as much as it does with this car.
I haveordered for a new BCM, a new gauge cluster and a new PCM.
What couldhave caused this and that that caused it, is it still present in the vehicle?Is that possible? What should I suspectand what should I do?
