Discuss A bit of advice on a Minor electrical installation works certificate. in the UK Electrical Forum area at ElectriciansForums.net
Top Cat
Took out a 6Kw shower, re routed 6.0mm cable to switched spur and ran 1.0mm to a pumped shower.
Is the overcurrent protective device for the modified circuit, the 32A 60898 breaker or the 3A fuse in spur?
Is the cable size the 6.0mm or the 1.0mm?
I am thinking it is the first in both cases but seems a bit ambiguous the way it is set out.
Cheers
Cheers
Haha
TC I started an almost Identical thread a few days ago.
Get with the program Boyo
It threw up some interesting discussions and the general consensus was to put it as a 6mm 32amp unless the Zs reading on the 1mm would constitute a failure on a 32a MCB then maybe record it as a 3a 1361 spur type thingy
Haha
Thanks Dave, any chance of posting the link? Sorry about not being up to speed with all the threads, i think about electrics for 99% of the time so must have missed yours on my 1% off!
The new MWCs (Elecsa ones anyway) have provision for 3 circuits giving you the opportunity to note both :)
Thanks for that just looked on my software package (Hollycroft) and has the same on there. Have to scrap the one i just did and re do it. Good job i don't have to pay for the certs! It gives me joy every time i do a cert knowing that the NIC are not getting a share of it! (apart from the obvious!)
So you could use the Elecsa one, record the Zs on the load side of the FCU for the 32A breaker, and then the Zs at the extremity of the circuit for the 3A fuse - and boy, if you can't get a reading to comply with the Zs for the 3A fuse you're in big trouble.
If its one or the other I'd say its the 3A fuse you are checking the Zs for!!
tin hat on
tin hat on
Think i will just ---- a coin!
I haven't got Easycert it is Hollycroft, brilliant bit of kit.
Was just saying that Easycert doesn't provide the option.
Just had a quick look on the holly croft site at their demos, and it actually look better than easycert.
Does it just run in word or something? Does it keep all you past customers details and stuff like that.
Think I might be moving over to Hollycroft TBH
9 out of 10 cats would just guess it. how much is hollycroft, TC?
Cheers
I can feel a major face palm moment coming on.
;-D
Yes you have to have a version of Word for it to work. All Certs are kept as a Word document.
If you have any queries give them a phone call you will get through to the owner who is really knowledgeable and friendly. Its nice to get the owner every time in this day and age!
Haha
And that is just cheating ! lol.
Just one thing to add TC,
1.5mm is now, as of amd.1, the minimum csa for power for anything other than lighting, 0.5mm for control wiring, see table 52.3 on page 130 BGB.
I got told it was in case someone replaces the 3A fuse with a 13A one, but how true this is I don't know.
Thing is if we are all gonna start noting fused spurs down as seperate circuits on a cert what happens when we do a kitchen? we fill out 7 extra circuits for all the appliances? hmmmm.....
Reply to A bit of advice on a Minor electrical installation works certificate. in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Hi everyone, I’m brand new to the site and hope everyone is doing well. My question is this: I have a 2365 level 2 diploma and have been doing...
Hi all, how do you go about filling out a EIC or a minor works certificate when you have multiple installers that have worked on the circuit...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
Hi, I've recently had my broken oven replaced in my flat and I paid for delivery and installation. It was hardwired through an unswitched plate...
