Discuss A bit of testing in the Electrical Forum area at ElectriciansForums.net
Resu
Mentor
Did a bit of testing recently for our local housing association. Found this in a communal area at the front door to a block of flats:
A bit of testing {filename} | ElectriciansForums.net
Yep, full of water!
Turned power off and drained:
When water drained battery backup kicked in! (Circuit was protected by 3036 fuse):
Also found this in a property, usual story, loose connection:
Not housing association but just as good:
The next one was a good one. Testing a village hall recently and having a bit of trouble with two "radials". Turns out they were wired as a ring and when someone nailed the cable and they couldn't find the fault (or didn't bother looking) they decided to change to two radials. We did a bit of digging and found this, which has been like this for about 30 years:
Needless to say all has been rectified except village hall which is looking like a full rewire is on the cards.
Another good one from the other day. Wasn't testing but noticed this while walking through a small agricultural shed, thankfully disconnected!
A bit of testing photo - EletriciansForums.net
I just watched a few episodes of Benefit Street and I think people in UK social housing are getting a bad rap. They seem like a nice bunch once you get to know them :)
until you find you need to get in to get an ECR done...
they know you are supposed to be coming round....
you try getting em out of bed before noon.....not a chance..
How did the fluorescent get full of water? It looks pretty sheltered where it is.
Probably under a flat roof that hasn't been maintained for years. You'll be surprised just how much water can get through a concrete roof where the weatherproof is totally shot. Then again, it could be a wooden frame tiled roof, where the tiles have been interfered with, and/or damaged.
So if as i suspect this is a back entry fitting, with no sealing around the cables entering the fitting, ...Wallah, a water filled weatherproof fitting!! lol!!
idiots that fixed it up will have just screwed up into that ceiling/tilt....probably straight through as well....
Just open a can of carling and light a spliff, the smell & sound will rouse them.
Reply to A bit of testing in the Electrical Forum area at ElectriciansForums.net
