Discuss A couple of AM2 questions. in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
51ddo
Hi all,
I'm new to this forum and its due to the fact that I have my AM2 exam this coming Monday.
I just have a few questions.
- Do I need to earth bond the cable tray?
- I know that the External Loop Impedance Test is on the incoming side of the installation, and that when testing i need to disconnect the main earth from the earth bar to test. The board is a 3 phase and so do I need to test between L1-N-E L2-N-E and L3-N-E or do I just take a reading between each phase and earth then obviously record the highest reading?
- For the insulation resistance testing am I right in thinking that;
- I need to disconnect the RCBO and the fly leads completely from the CU?
- Disconnect the Lighting circuit and remove the lamps so that i can test the circuit when operating the switches?
- Disconnect the incoming supply for the CU to my motor contactor and place in push in terminals so that I dont damage the contactor?
- Disconnect the load from the unswitched fused spur for the co2 detector?
Then do a global test for the rest of the circuits at the main switch? i.e L1-L2 L1-L3 L3-L1 L1-E L2-E L3-E? Or go across each circuit individually at the cu?
Anyway thats enough so far that I can think of. Any help would be fantastic!
Cheers,
Tom.​
Reply to A couple of AM2 questions. in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi all, hoping for some advice, I’ve recent resit my AM2s after failing on first attempt… I’ve passed all my resit apart from section C just on...
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
Anyone come across this before? I was asked to do a Zs on a 3ph surge device; L1 was around 6 ohm, L2 & L3 around 0.11. Wired in singles from a...
Fluke MultiFunction Tester 1662 TNS Earthing system. Switchboard - 415v - 3 Phase + Neutral + Earth. MCB 1000A 3 individual Earths (185mm)...
resitting Saturday my am2 4 sections a3/b/d/e swa and sy failed on protective conductors on both swa i under stand thats the earths i...
