- Reaction score
- 5,602
I have been umming and arghing about a torque screwdriver for some time but have not yet bought one.
My fears are the following:
1. There are set torque settings that conductors in a consumer unit should adhere to. However, in the neutral bar which are screw terminals I tend to screw a 6mm in tighter than a 1mm (for example), as if you screw in a 1mm too tight it can shear. You can screw in a 6mm pretty much as tight as you can without fear of it going through the copper. I cant see how a torque screwdriver distinguishes between a 1mm and 6mm. Does it? Does it need to?
2. Are torque screwdrivers always accurate? If I use my normal screwdriver I have a 'fairly', if not 'very' precise feel for how tight I have made the connection. This experience will only improve over the years and you will make varying degrees of tightness as required. You lose this with a torque screwdriver and put all your trust in the mechanism.
I wonder if a torque screwdriver may not be a good option for someone who knows how to use a screwdriver properly? However, I am very much open to persuasion hence the post.
