- Reaction score
- 57
A strange one :- replaced an inline mixed flow timer fan like for like yesterday. When powered on at the 3 pole isolator switch the fan was running at 25% speed and the shower light 12v halogen bulb was lit but very dim (note the pull switch for bathroom lights was off) All other bathroom downlights were off. When bathroom pull switch was turned on Both fan & shower light went off, bathroom downlights worked correctly.
All wiring correct on check. Checked 3 pole isolator loose neutral connection found. Retightened everything working as normal.
trying to work out why this would cause the fan to run slowly/dim downlight any ideas much appreciated.
