Discuss A127 Alternator Indicator Light Sizing in the Auto Electrician Forum area at ElectriciansForums.net
aesmith
Hi,
I'm intending to fit a standard A127 type alternator to my Chinese tractor, replacing the original with it's troublesome external regulator. I'm happy with the wiring and principles except for one thing ... can anyone put a figure to the current needed via the indicator light in order to kick the alternator into life? There's no charge warning light at the moment so I need to fit one, and wondered what size bulb is needed. Also wondering about fitting an LED indicator with a resistor in parallel to provide enough current.
Thanks in advance, Tony S
Hi,
There's a thread about this here, it doesn't sound too critical, if you want an LED it looks as though you can fit a 47 ohm 10W resistor in place of the lamp and connect the LED/series resistor across that.
Hi,rule of thumb,with all the Lucas type stuff,was 2.2w filament lamp,usually screw type. Some didn't need one,others would not charge without one...no self respecting auto-electrician,would be short of one in his tool bag. Try it with a slightly easier to source lamp,like a 3w capless,wiring is straight forward,just ensure the charge lamp feed,goes through the ignition switch :)
Thanks, I think I'll check the installation with a 2.2 or 3W bulb as suggested then look into LED for the final fit. Reason for LED is that I want the indicator to be weatherproof.
Reply to A127 Alternator Indicator Light Sizing in the Auto Electrician Forum area at ElectriciansForums.net
Hi all, first post so be gentle... I've recently decided to replace the MR16 50W Halogen bulbs in the bathroom with 5W LED ones. I'm aware of the...
Hi everyone, this is my first post in this very lively forum! Thanks in advance to those who will answer my (hope not too silly) question. I'm...
Hi everyone, I was wondering if I could get a little advice on a small project I plan to carry out over the next few weeks. I plan to install...
Hello all, New to this site but have been doing DIY electrics for about a year now. I'm looking to upgrade the lighting in my living room to...
4K
Hi. I am off grid, UK. There is no grid tie or connection and there is currently no potential for connection. Background: I use a Honda EU10i for...
