Discuss Abacus control panel. To bell box in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
den123
Hi all I have a abacus panel I want to put new bell box in It’s a Texecom premier odyssey 1e. Can anyone please help has anyone got instructions for wiring please. Also. 2nd question can I use any keypad with the abacus panel. I have a Texecom panel is it ok to use if so looking for wiring dig ram the key pad is TEXECOM VERITAS. thank you all
should have wiring diagrams with new sounder for various panels. and you can't fit a texecom keypad the an abacus panel.
Thank you for your help I have taken photos of new bell box. And old bell box. But not sure where the wires go
on new box, you missing the black. that goes to 0V, between the blue and the white. if you haven't blown a fuse in the panel, it should work.
edit.justhope your wiring skills are better than your photogrqphy skills. :rolleyes:
Thank you all for your help you are all brill
Reply to Abacus control panel. To bell box in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all Is it possible to connect a Texecom Odyssey 1E sounder to an Optima panel using 4 core cable and still allow the bell, strobe and tamper...
I’ve recently moved into a property with a Texecom premier elite system. I’ve been given the engineers code and have read up on the alarm. It...
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
Hi, My alarm system is a Texecom control unit (Premier 64-w) + Keypad + Sounder, and is using the wired zones 1-4 only, with no additional...
I used to fit Bell door entry systems all the while about 20 years ago but I'm a bit rusty on them now, am I correct in saying if you use a DC...
