Discuss Absence detection with retractive switch in the UK Electrical Forum area at ElectriciansForums.net
A
almost_there
Im looking for a bit of advice on how to correctly wire/connect an absence detector and retractive switch using a 5 core lighting trunking.
Not had to do this before, but been asked to do this as a homer in a small office
cheers
Welcome to the forum almost_there, you are down as a Trainee, if you are still on a course you could apply for access to our Trainee Section where we have a selection of Mentors to help out with trainee level questions, if your interested that is.
Try searching the web for "Dali ballast wiring" which should bring up some results. There will be a permanent feed to the lights and then a pair that connect to any PIR's or switches.
It is all to be done via 240v. I have worked on Dali systems before, which were simple. But never had to do it on mains!
If you're just using standard light fittings you can feed the PIR first and then a contactor and the refractive switch on the load side of the PIR. I'm mobile at the moment so I can't post a wiring diagram.
Reply to Absence detection with retractive switch in the UK Electrical Forum area at ElectriciansForums.net
I've a light fitting that's controlled from a Whitecroft absence detector PIR and a wall switch. The way it works, is the Retractive wall switch...
hello guys, hope you’re all well. We are looking at installing the Hager SFT240 changeover switch to three live aboard boats with an electric...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
