Discuss Accenta help in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Dave Appleby
Good afternoon all.
I have the dubious honour of trying to resurrect an Accenta 8 mini G3.
All looks good except.....
The client pulled ALL the fuses including the PCB glass.
So I have 4 fuses and no idea where they actually should go as they are a mixture of QB and TD. All different ratings of course.
I have the engineering manual but no circuit diagram.
So, just asking. Can anyone let me know the correct values for fuses F1-F4 on the main PCB?
Thanks.
i can find out in a bit.
[automerge]1598461958[/automerge]
3 fuses to the right of the terminal strip. from left to right... F5 = 1A. F3 = 1A. F1 = 1.6A.
fuse on the left of the board on it's own, F2 = 1A
so all 1A except F1, which is the battery/charging fuse. i would imagine this one is slow blow/anti-surge.
Fantastic.
Now... Is the anyway to kick it into a factory vanilla setup?
House has changed hands. Old owner is unobtainable in Sicily.
Whole problem started with that smell.
Client assumed it was the alarm. Wrong...
CCU was below.
See the full joy I had. I've seen this kind of damage before but never actually taken the cover off to find it a rather nice glowing red/white...
  • Accenta help IMG_20200825_160151 - EletriciansForums.net
power up panel. within 5 seconds press reset twice.sounder will bleep. then you are back to default. user 0123. eng, 9999.
Fantastic.
CCU was below.
WOW that’s burnt real bad
Reply to Accenta help in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
