Discuss accenta mini alarm setup help in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
P
paulsanderson
hello, i have just installed a new accenta alarm and although it works for going out of the house, i can't seem to get the program 3 night time to work?? i have disabled the upstairs zones on the key pad but if i set it and walk upstairs it still goes off?? am i being thick?? any help greatly appreciated :D
you need to select the upstairs detector/s as off in part set.
hello
thanks for your reply, when i setup program 3 in engineer mode i deselected the upstairs detectors and when i go back in to check them they are off, but when i go upstairs they then set alarm off?? even though they aren't selected in the program?? am i missing something really easy? because i'm sure it shouldn't be this involved??
thanks
How to Omit zone(s) on setting
system
During the exit period after entering User code
and selecting a
program press
OMIT, the exit tone
will stop and zones
that are about to be
armed will be
displayed. Key in
the zone number(s)
to be omitted which
will flash to confirm
selection. Zone
indicators which
show steady are still
about to be armed.
When the selection
is complete press
Set and the exit tone
will start.
don't know that panel all that well, but the optima it is based on does not have part set modes. you have to omit the relevant zone .
Reply to accenta mini alarm setup help in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
hi guys, looking for a bit of help on the above alarm, how do you setup the alarm so that you can turn off pir zones at night time. thanks in advance
