Discuss accenta mini alarm setup in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Or you can 'omit' zones after putting in your number.
hi, just to let you know i'm a spark so don't think the same way as alarm engineers, here's what i've tried so far, in engineers mode - programs - selected - program 2 then inhibit zones 2 and 4 theyv'e got pir's, exited then tried user code then p , suppose to stop so you can choose which program you want, but it doesn't, it shows as program 1 set on keypad, am i doing something wrong. by the way it does work when you omit the zones manually, but with females in the house it's a bit complicated.
update: i had to set the exit mode to timed, it's now letting me set program 2 ok ,but the pir zones i've selected as inhibited are not disarming after removing link, i'm doing a bench test on this at moment, the zones disarm when removing the link with the omit button.
Reply to accenta mini alarm setup in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi, I have a veritas R8 alarm and corresponding keypad. Recently a powercut caused one of my keypads to stop working. I replaced the battery in...
Hi All, Might be a stupid question but I have about 30 of these smart+guard alarmed call point covers to deal with. All the batteries are dead...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
