Discuss Accenta/Optima LED Double Knock Problem in the UK Electrical Forum area at ElectriciansForums.net
R
Rudie
Hi,
I am trying to set up double knock on some zones on my alarm but having a problem. In the manual, it says to press the BELL and then press SKIP and LEDs 1 and 2 should come on - which it doesnt, all i get is a long BEEP.
What am i doing wrong?
Thanks in advance.
You need to enter engineer program, then press 6 for attributes, press 1 for double knock, then select zone number. Then reset x 3 to exit program
Hi,
I dont have a reset key only the 'X' key, I have the Optima Compact with built in keypad 8EP396A
Rudie all ade have reset buttons, remarketed A1 systems had x are you sure your have accenta and not an Advantage panel.
photo of panel would help
No but i can see were you have gone wrong.
OK enter engineer mode, by pressing P then engineer code or 9999,
Press the eye button,(zones 1/2 lite)
Press 1
Press zone number 1-8
press bell button (zone led will lite)
press X button twice
That manual is a bit missleading
Hi, when i press 'P' and then enter thr engineer code, that works. But when i press the eye, i get a long beep and dont get led 1 and 2 lit up...
ok that means the incorret engineer code has been entered, or changed. if you dont know the code follow page 17 with link wire, and return the panel back to factory settings, engineer code will be back to 9999
ok thanks tazz will try that. i assumed the eng code would be the same as the arm/disarm code.
will check this later today. so the SOS light should come on when i enter the engineer code?
the eng. code is totally different from the user code. try 9999. if that doesn't work, do as tazz said.
Telectix, have a look at the manual Rudie posted earlier, its total different from original ADE accenta/optima, and check If I have got the double knock program right.
follow the steps on page 32 of the manual.
Reply to Accenta/Optima LED Double Knock Problem in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
5K
Hi all, Just an old problem I wonder if anyone can advise me on. First of all I do not have the engineers code to my alarm, I have read...
7K
Hi, I’ve been asked to look at a ADE optima compact plus as the zone 1 light is activating and it beeps everytime the PIR as activated I.e when...
11K
Wondered if anyone can help please. Just installed the above & initially had a problem with tamper lock out ! Suspected the exterior bell/strobe...
Honeywell ADE Accenta G4 panel & 8EP417A RKP Wondered if anyone can help please. Just installed the above & initially had a problem with tamper...
6K
