• IMPORTANT: Please note that nobody on this forum should be seeking from or providing advice to those who are not competent and / or trained and qualified in their field (local laws permitting). There is a discussion thread on this global industry-wide matter HERE. This also has more information about the warning with regards to sharing electrical advice in some countries. By using this forum you do so in agreement to this.
Instyle LED Lighting Specialists UK
Discuss Access Path of more than 100 feet high building in the American Professional Electrical Advice Forum area at ElectriciansForums.net
Hi,
this is from NYC fire code. does anyone knows if there's a code for building more than 100 feet. Thanks
" 504.4 Rooftop Access and Obstructions
The rooftops of buildings 100 feet (30 480 mm) or less in height, except rooftops with a slope exceeding 20 degrees (0.35 rad) from the horizontal, shall be designed, installed, operated and maintained in accordance with this section and in a manner that avoids or minimizes obstructions that impede firefighting operations such as vertical ventilation of heat and smoke, surveillance of rear yards and courtyards, and rooftop-aided rescues. "
telectrix
Mentor
You must be logged in to see the message.
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Reply to Access Path of more than 100 feet high building in the American Professional Electrical Advice Forum area at ElectriciansForums.net
CK Tools :) The professionals choice when it comes to Electrical Tools
Top Bottom
