Discuss Adabtable boxes in the UK Electrical Forum area at ElectriciansForums.net
keniff
Hi guys, what's the advantage if any of using a galv adaptable box over plastic? Other than strength, if you use pirana nuts you earth the gland either way? I suppose if you used a metal box you could earth the box for multiple armoured glands save loads of fly leads?
about right. also, where livestock are concerned, galv. boxes withstand stupid animals kicking and biting them better than plastic.
Lol oh right, so would it be acceptable to earth many glands with on fly lead to the box rather than many to each gland or is this bad practice? I normally flylead each one individually
nowt wrong with belt and braces. at least nobody will have your pants down over that.
Reply to Adabtable boxes in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
What would of stopped this happening? Job I did this morning. SWA supply for outbuilding had sliced basic insulation at the gland due to poor...
I've got a bunch of old single phase BS88 1970s fuseboards in the communal areas of a converted building. All the wiring is MICC and it's buried...
