Hi,
Recently had 3.6kw solar installed, at the time shortage of batteries & roi figured batteries not quite worth it.
thinking otherwise perhaps now with such big increases coming but mostly would really like battery backup.
Reading conflicting info.
from what I understand a A/C battery system would be best as already have a plain inverter so might as well add another for the battery instead of changing to a hybrid.
Can this be done with minimal expense as a backup?
I know has to have a fail safe so as not to power the grid if a power cut.
I was wondering if the inverter can detect mains-in and isolate itself & only when you turn off the mains-in breaker in the CU will it then allow power from the battery & the solar tops up the battery I hope.
Don't need auto switch over.
I guess draw from the house could be an issue so have to make sure not to use power hungry devices.
Just would like lights & internet etc. to continue to work
I have small UPS for some devices but just last minutes & seems like a good idea & also be able to store excess kw generated.
My supplier does not offer FiT or whatever the new one is called (not smart ready!!) so they get my kw for free, even with a feeble 5p per kw better than nothing.
Thanks I/A
Thanks I/A
