Discuss adding a second meter in the Industrial Electricians' Talk area at ElectriciansForums.net
salisbury spark
Hi-guys
need to add a second meter to house off existing tails..
(new shop consumer unit going in )-customer wants to charge shop for electric used.
Do i put two DP breakers in an enclosure 1 out too existing consumer unit and the other going off to new consumer unit? any advice welcome.Have no problem with 17th regs just how to add meter. thanks(part p qualified)
Hi and welcolme.
I would split the tails in henly blocks after the master meter then to DP isolators. Out of one to your existing CU and the other to the new meter.
Reply to adding a second meter in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
DNO ripped out antique main incomer/breaker .The guy hated us and himself and everyone else by the end of the job ! . Client going to contact...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
Looks very strange to me. Obviously had a new fuse carrier fitted to it at one point but the two cables on the left go to the meter as normal...
