Discuss Adding a socket in cupboard in the Electrical Forum area at ElectriciansForums.net
https://Upload the image directly to the thread.com/a/m8Xxr https://m.Upload the image directly to the thread.com/a/uknCe
Hi, this burglar alarm is not required, can I disconnect the burglar alarm and connect cable to a double socket instead?
no pic. if the FCU is on an existing socket circuit, then OK.
Burglar Alarm not needed in Glasgow, Crikey mate, you lost the plot or what?
New house, electrics have been done recently, the burglar alarm is the only thing connected to the box and it's in off position. If I turn it on power goes to the alarm system but I'm going to remove it. Options are connect it to a double socket if safe, if not, connect it to a dead end and leaving off position
Looks like the switch to power the burglar alarm is connected directly to the meter, get a sparks in to sort it out properly by removing what isn't required and then wiring in a socket from the CSU.
The cables supplying the grey switch are permanently fed from the meter. You need an electrician in.
Indeed, get someone in. There’s two tails going into the meter terminals and that ain’t right.
Have the electrician completely remove the grey switch fuse and all the associated cabling. If you want a socket it must be RCD protected. Have the electrician provide one from that nice new consumer unit in the photo.
I think you’d be better off getting an electrician in and having it all stripped out back to the meter .....can’t believe they’ve left that in place!
Surely the fuse is in behind the cover of the MEM unit. There's no RCD protection for a socket outlet however.
Reply to Adding a socket in cupboard in the Electrical Forum area at ElectriciansForums.net
