Discuss Adding a 'spur' to a ring circuit. in the UK Electrical Forum area at ElectriciansForums.net
Billio
Hello All
Possibly a silly question - can I add a 'spur' to a ring circuit at it's MCB in the CU, rather than cutting into the ring itself? I want to do this to add a power line adaptor to extend wifi coverage.
Many thanks.
Billio
not a problem. as long as it's done correctly. N to the correct N bar and E to the correct E bar. care taken to ensure the 3 connections in the MCB are sound.
Great, thanks for that. I thought I could do it but got different opinions - I think they were winding me up.
Billio
As Tel says, not a problem, it is a spur at the origin.
But you will sometimes come across electricians who seem to think this is wrong, maybe that you are connecting two circuits to one MCB or something.
No problem with this , you could also extend the ring at the consumer unit Using wagos if you need more than one new point...
Thanks for your advice - I thought I'd make it neater by simply adding new 2.5T&E rather than Wagos, but then again, Wagos might be even easier?
[automerge]1590305289[/automerge]
What is the value of the MCB? If it’s 32A, you’ll need to use 2.5mm T&E for your spur.
Thanks for your reply, it is a 32A MCB and I'll use 2.5T&E.
I don’t see any qualifications on your profile page. Are you an electrician or DIYer?
Just wanted to add that taking off the CU cover exposes live parts. Turn off at the mainswitch or isolator if you have one.
An extra socket should be RCD protected
Reply to Adding a 'spur' to a ring circuit. in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Evening all, Been to a job on Fri where the customer had a condition report completed. Two of the remedial identified was that there were too...
