Discuss Adding a spur to a spur in the UK Electrical Forum area at ElectriciansForums.net
I have a socket which is connected off the main circuit ring.
Just wanted to know if it's possible to add another socket spurring off this second socket?
(Please see attached image.)
If it's against regulations, then
1) what's the worst that could happen? (Will my circuits blow up?)
2) what's the best alternative and what size wiring will I need?
Zahid
You are allowed 1 Spur from any socket that is part of the Ring on a Ring Final Circuit, in other words if the socket you are intending to spur from is not a spur, the yes you can add 1 socket, either a twin or single socket constitutes a spur.
I you wish to add another socket from the spurred socket you will need to spur that extra socket from a Fuse connection unit (FCU), in laymans terms that will be original spurred socket, FCU and as many sockets as you like from that FCU Appendix 15 of the BS 7671 Wiring regulations explains all.
As @Pete999 said above. change the first socket that is spurred off the ring to a fcu then add what you like to that. In the event you over load the fcu then the fuse inside will blow but should not affect the ring feeding the fcu. Just check what fuse is inside the fcu as it is not unheard of for people to put a 3 amp fuse in or buy one with a low rated fuse and just fit it without checking. then wonder why things go pop.
I do get a bit of a hump with diy'ers, just because of the nightmares its cause me in my travels in domestic properties, years later down the line.
I've learnt a lot myself from learned forum members, in the past few years, but some comments made about such threads as these, do make me sigh. You can be dismissive in your comments, but in a constructive way. Does this forum no good, by just taking the ----.
If due to practicalities and you can't install at least the first (or both) socket(s) on the RFC could derate protective device to 20A but this will depend upon the existing loading(s).
I've learnt a lot myself from learned forum members, in the past few years, but some comments made about such threads as these, do make me sigh. You can be dismissive in your comments, but in a constructive way. Does this forum no good, by just taking the ****.
You nearly got me there, have a laugh and see banter makes like a little bit more liveable, nice try ;o))))
It is an interesting phenomena that anyone other than a bona fida time served electrician with at least 100 years of experience is incapable of altering a ring circuit and it remaining a ring circuit on completion.
Given that a circuit really does not get any simpler, just a big loop, it really does defy logical explanation.
Kev is the worst offender, I have never, ever come across a kitchen ring altered by Kev that is still a ring. It should be a legal requirement that any sockets altered or installed by Kev must have the OCPD reduced to a maximum 20a. Mind you, Kev would see that as a green light to wire his multiple spurs in 1.0mm.....so prap's not.
Reply to Adding a spur to a spur in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi everyone, I've got an electrical ring circuit that looks somewhat like the drawing below, where the blue sockets are part of the main ring and...
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
