Discuss Adding a strapper to a 3 gang light switch. in the DIY Electrical Advice area at ElectriciansForums.net
Wanchai
Hope someone can help, apologies I’m new to this. I have a two gang switch for ceiling lights (work perfectly) which I am turning into a three gang in order to add a wall light. I have successfully connected the new three gang for the ceiling lights. As I’m unable to take a spur from the existing N in the ceiling I would like to add a strapper in the switch for the wall light but confused by all the diagrams on line. I have linked up the L and the Spurs in yellow for the ceiling lights are from L1 on the two switches. Appreciate any help!
Is there actually a neutral at the switch. A pic may help.
Thanks for your quick reply! This was the two gang which I have wired as a three gang with the spare switch meant to be for the wall light.
Your missing the neutral, you will need to get one to the new wall light
Thanks Phil
I was led to believe that instead of a neutral that I could use a strapper in the light switch. I obviously have the L and N from the wall light ready to connect and understood that I would need a N or a strapper? The problem I have is the concrete ceiling would have to be chiselled to insert a N and I was hoping for a simpler solution.
Reply to Adding a strapper to a 3 gang light switch. in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi, I am wanting to add a couple of wall lights to a room that currently has a single ceiling rose. Attached are photos of the one gang switch and...
