Discuss Adding aditional lighting to switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
dixie
Hi, I'm trying to change the double light switch at the top of my stairs to a 3 way switch (for lighting in attic). I thought it would just be a case of adding another cable to lights and swapping the original wires from old switch to new switch.
On the old socket:
Switch one = Bathroom (light controls fan)
Switch two = Hall
All neutral wires are together in a small joining box
The new faceplate im trying to put on has standard l1 l2 x 3
but also has 3 extra inputs.
Sorry im getting myself really confused now. I have pictures if anybody needs them.
Take a twin and earth to the loft light from switch. There are no extra connections just marked up differently. Commons are still commons. Connect up new switch leaving 3 switch empty. Now you have your new cable to loft light. Connect the brown into L1 and take a loop of cable from the second switch's common into switch 3 common to feed your loft light. The blue to the loft goes into the neutral connector block and obviously connect the earths together that is important. Hope that's helped a little bit.
Help: Adding aditional lighting to switch
Now i have ran into another problem. All switches working but when switch 2 is off, switch 3 doesn't work. Also i was wondering, due to the mass amount of wires and the sheer awkwardness of it. is it possible to have ie 4 brown wires into a connector box and have 1 brown wire coming from the other end.
ie, say l1 has 3 brown wires going into it, could i put they 3 wires into a joining box then have 1 brown wire coming from it so you only need to fiddle with 1 wire instead of 3. and the joining boxes could be hidden in the wall
sounds like you've taken the feed to switch 3 from the wrong side of switch 2. and don't be so impatient. even us gods need to eat sometimes. LOL.:ciappa:
but is com 2 the permanent L or is the feed to sw2 on L1? that's how it looks in your pic. but can't be sure from a pic.
nothing like a bit of trial and error. red to red, black to black, blue to bits. LOL.
I think a pullcord in the loft may have been easier. Feed to switch. Live connected to c and l1 to lights. Neutral connected through to light fitting.
thats the switch all connected properly now but is it possible to have ie 3 brown wires into a connector box and have 1 brown wire coming from the other end.
You'd still have to link the commons together so that's more wire!
I have no space for a bigger backbox, the com wires arnt the problem, the backbox has 6 x twin&earth going into it.
1. Bathroom Light
2. Hall Light
3. Loft Light
4. Loft Ariel Socket
5. Bathroom fan
6. Mains wire
Reply to Adding aditional lighting to switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
