Hi
Just a quick one, I am a qualified electrician but i haven't been on the tools for a while and won't be doing the work but just trying to help a friend out.
Basically they are having a new kitchen diner and they currently have gas hob and small single oven which are fed off the ring main. They are wanting an electric induction hob (7.2kw) and combination oven (3kw) so i said they would need 2 new separate circuits for these.
However they have no spare ways in their DB (older style 6 way DB with RCD) ideally they would need a DB upgrade but in the past someone has installed the combi's boiler in front of it (amazing) and can only just get in turn reset an MCB.
But they have 100A main fuse with 25mm tails that is split already one to the main DB and one to 60A large switch that has a 45A fuse in that just has the garage SWA supply to it, my question is it just possible to replace this 60A switch to a small 4/5 way DB single RCD that will house garage supply (down rate to 20A) Hob circuit (40A) and Oven circuit (20A)
All advice and options welcome
